Ok. So I was installing the Stillen hood dampners today. Well when I'm putting the bracket on the headlight support and trying to tighten the bolt... it just keep spinning. The bolt isn't tightening. I know the HOLE is stripped and not the bolt because I switched the bolts from the passenger and driver's side, and the passenger side still tightens.
http://www.stillen.com/product...t.pdf
If you don't know what I'm talking about, it's the bolt in photo 1 or 2 in the Stillen directions.
What would be the best way to correct this? Do I need to take a slightly larger drill bit and make a bigger hole and use a bigger bolt? Or should I just try my luck with locktite?
And yes Medi, I'm doing it your way. Rod down!
