silvia s14.5 rb25det »
https://forums.nicoclub.com/silvia-s14-5-rb25det-u95407.html
Fri May 29, 2009 5:28 am
I was putting the cams in on my ka and started to torque them down. I started with half the spec all the way around the cylinder head. a few of the caps couldn't even hold that and stripped out. I used the manufacturers torque spec. Torqued the rest of the caps down. by the time I was finished 7 bolt holes were stripped out. previously I had the head taken the a well known local machine shop called T-Hoff for resurfacing/ cleaning and they checked the rotating assembly with caps and cams.
The first solution my friend and I thought of was to heli coil it with the same 6x1 size as the bolt. The heli coil (6x1) is almost 2 millimeters larger in diameter than the hole, which is normal for a 6x1 heli coil. but on the Ka24de the clearance between the cam journal and the hole is about 2 to 2 and 1/2 millimeters. so basically the drill bit used with the tap with the 6x1 heli coil would over bore the bolt hole into the cam journal. the next solution we thought of would be to get a smaller but same thread pitch heli coil like a 5x1. I couldn't find a 5x1, but there was a 5x.8 heli so then we thought well maybe we can dye the bolts down to a .8 thread pitch. but dyes are not normally used to make threads rather than to just clean threads. i tried the 5x.8 but they literally just drop into the 6mm hole. and you can't get new bolts because the original bolts are locator bolts. trust me unless these bolts can be custom made the it's not happening. The only other options I could think of to fix this problem would be to sleeve the holes, but that raises the question of how are you going to lock the sleeves in? Or fill, drill and re tap the holes or just get a new head. Yes I know they are cheap but I have put money getting this S**t machined. I have taken a trip back to T-hoff and talked to the guy that serviced the head and he basically told me what i was thinking.
so is there anyone out there that has had this problem and has fixed it successfully without getting a new head?
Modified by silvia s14.5 rb25det at 3:27 PM 5/30/2009
Modified by silvia s14.5 rb25det at 3:33 PM 5/30/2009
