Stripped oil feed.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
Ok so my oil feed is stripped. I want either retap or helicoil. My banjo bolt is fine in good condition. My current problem is that my banjo bolt feels loose when u start but tightens up towards the end but won't torque. Feels like the bolt is too small at the begining but before torque down feels like its the right size. Oil feed threads look ok not really tore up and stripped completely
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
I would try some Teflon tape before you tap. Just a thought.
USMCgetsome
Tried but did not help. Still pisses oil everywhere.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Yeah, banjo fittings seal with two copper crush washers, not the threads. So tape isn't going to help, in fact it might even clog the line.
You'll have to use a thread repair (helicoil, time-sert, etc), pretty much your only option. Unless you want to drill and tap it out larger and use AN fittings and hoses.
Lobo240sx
Yep you need those copper washers or else it will also leak. get aftermarket lines and get rid of those pita stock lines. Those get brittle and break.
