Clawhammer »
https://forums.nicoclub.com/clawhammer-u53050.html
Wed Jan 28, 2009 3:03 pm
Yeah. Go me.
Didn't even know it at the time. After changing my HG and putting it all back together, I started it up and it's shooting oil out the side of the block. Oops, did I forgot to tighten it down? Maybe I just put it in by hand?
So I get down there and it's loose. Just kept spinning though. Don't know how I stripped it the first time without knowing..
So what now?
Should I circumsize the bolt? Plug it and get a sandwich plate and run a line from my oil filter?Heli-coil?
I already tried the JB weld trick. For those of you that know it it didn't work because the bolt bottoms out and then I can't get the banjo tight enough to not leak. If you don't know, don't worry about it lol.
Oh this totally blows.
