stripped oil feed port in sr20det block
crookedcop7
Car: 89 nissan sileighty
I have a black top sr20det motor with a 2871r garrett turbo. I had it installed at pruven preformance in ct. Today I change my oil and after a 10min drive I returned home to find my car pissing out oil. After further investigation I found it leaking from the oil feed port after taking off the banjo bolt I saw the block with stripped (and bad)
I dont know what to do would tapping the block and replacing the banjo bolt and fitting work
I need a solution please help....... thanks in advance
Hijacker
Car: '92 240sx Convertible
'94 F-150
The best bet would be to install a helicoil. Unless the threads are just marred up on aluminum, retapping won't solve the issue.
crookedcop7
unfortunely there are no threads left i talk to a custom motor shop the 2 options they gave me are1. plug up the original oil feed port and tap a new one somewhere else in the block
2. retap the block and change the bango bolt and fitting
if they do that then I can request a helicoil
or should i just start lookin for a new block
