C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Jun 28, 2003 7:31 am
Don't bother with WD-40. It's crap as far as using it as a penetrating oil. I use some stuff called Pro-Lube(comes with the Dura-Lube engine treatment kit, I don't endorse Dura-Lube, a friend of mine uses a lot of it and has tons of the Pro-lube stuff sitting around).
If you have access to Metrinch tools, and there is enough of the flat part of the nut still left, try it. Metrinch is great for this kind of stuff. Make sure to use a good penetrating oil with it though. Makes a huge difference. But then again, the damage may already have been done and the threads may have been damaged already. In this case, even with a good grip, you may just end up ripping off the stud.
You can also get a nut breaker. But somtimes, it's hard to fit into tight areas. Most auto shops will have this tool.
