black g50 »
https://forums.nicoclub.com/black-g50-u193128.html
Tue May 29, 2012 11:48 am
Went to the salvage yard over the weekend.Picked up the only fuel tank remaining,for a spare.Got it home and used the oe length screws to test it,stripped...or so I thought.Looking inside the main hole,You will see (2)tabs where the screw holes are that look like a clam opened up,I took a long screw driver and forced them to close up a lill,put screws in and they bit into the metal and seated quite nice.I also tried it with longer screws to the same result.You can see the clam opening as the screw goes through it.So longer ones are ok after all.Save your tanks!!
