StricNyne »
https://forums.nicoclub.com/stricnyne-u10935.html
Mon Jun 16, 2008 9:26 am
OK well here goes guys... the car is almost done
Motor is installed after all the mounting issues i had, i finally have all turbo intake piping thnx for Scott Buwalda. Pretty much no wiring is done at all... i picked up a premade harness from scott but much of it is cut out since this was done in his showcar, like idk if speedo works (my lower harness only plugs into relay box, no where on main harness ) or if tach works, but i have a apexi pfc and i can monitor rpm with that (the cmdr) i am still waiting on my fmic piping from otis @ rb performance its been exactly 19 days so idk whats going on with that....lets see, i am trying to get a local shop to make me a custom dump but i think they are all retarded or want in the ball park of 1k for it... i wish i went single but its a tad too late for that unless i am guinea pig for a obx and turbo manifold combo.... also back to wiring i scored a rb26 harness with a busted main plug for 80 bux, gunna try and get a s14 obd2 harness and make 2 engine harness, but info is lacking on rb26 wiring, what else... hmm, yeah so basically mechanically my car will be done in a couple days, and if wiring goes well maybe 1 week it will be done i got some pictures incoming
some questions i had are
what is the exact flange of the stock rb26 turbo on the exhaust side, i bought a t25/t28 which didnt fit for **** so i can add it to my box of flanges and gaskets, i swear i have enough flanges to turbo ANY vehicle with ANY turbo !
as far as wiring, should my lower harness plug into my main harness some where because NO plugs match up but like i said this is a barebones harness
for wiring in resistors, i shoulda followed boostedz advice and wire a resistor to each inj but instead i bought a ****ing accord one which i thought was PnP but obviously its not, had anyone gone this route if so what did you do to correct it ?
how the hell do u remove the dipstick tube, my motor had it taken out and it was lost, i got a spare motor with a dipstick but it dont wanan come out is it threaded or do i just yank on the ***** to make it come out
also since i am running a rb26 pfc and rb26 harness will it wig out with my rb25 cluster ? i want to wire it in since i cant afford racepak i want but thats a lot of work for something i cant promise will work
Work left-I pretty much need to work on wiring, of my gauges to approiate sources, i did some thing really cool with my vct solenoid but i need a plug to finish it up , i also need to do the wiring for a z32 ptu, then i need to check all bolts, add gear oil and hope it dosent either seize or catch fire i am gunna post up some pics of the car as it is, and hopefully once otis sends me the fmic and piping when its almost done !!
