StricNyne Car Update
StricNyne
Just thought i would post some status of my setup, well i blew my intake manifold gasket, and i already had a spare exh gasket so i am doing them both, i got the exh like 90 percent done. the intake one comes in tommorrow i ordered one of those thermalnator gaskets thats made out of plastic, if i use the gasket adhesive from permatex u think it would be ok ? i am doing it for my exhaust one for sure ! out side of that i am installing my new sway bars in the front and rear ( godspeed / intense power ). I am also replaceing the valve on my crankcase evac with the beefier NAPA one it only cost like 5 dollers, btw crankcase evac is the s***. My engine bay was redone by a friend KFL he is on NICO too
Uploaded with ImageShack.us
m tr4nch
Car: RS13, Z31, P11
ahhh looking clean as hell now man.
great job with that powdercoating alex, wow!
sucks you blew the gasket but good thing you got one overnighted from japan... Image
meet07
Car: 89 180sx rb25det
I like the engine bay too. What kind of regulator is that your using? And considering doing the same thing with the crankcase evac setup. Seems alot cleaner!
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Super clean but it's super mean
bmxarmy
Car: 1961 AMC Rambler
Deadly! everything looks real good....More info on crankcase evac? Also what manifold are you using for the hx? modified stocker?
P.S. where did you get that sick coil cover? :) haha.
Gabes13
Car: rb20det s13
Dang, I'm jealous.
StricNyne
its a 6boost manifold from australia guy name Kyle makes them from time to time, the coil cover is pimp tastic, the regulator is a tomei large diaphram for high hp applications (so they say) i have it setup for a dual feed to my rail with an lines. The crankcase evac is really awesome it just uses the pressure from your exhaust to make vacuum in the block, i have it going to a air to oil seperator ( which it seems like i dont need since its been bone dry since day 1) than to my exhaust. When car is idleing its hard to take of the oil cap, you just want to make sure everything is sealed up and then its a go go
l0nestar
2004 Toyota Altezza
I was wondering what your vac source was. I did the opposite of you, I used my intake (pre turbo, post AFM) that way it's always under vacuum. But since your not running an AFM (or went blow-through) it wouldn't work.
neonbomb
What happened to the twins?!
StricNyne
yeah i am map sensor now whooo !!! twins was a long, troubling demoralizing road lol
StricNyne
lil update, found exhaust leaks on Head to manifold, turbo to manifold, turbo to dp, manifold to wastegate lol fixxed all of those, now i just fix the coolant issue with my intake manifold and car should be golden, i sooo do not feel like doing this, on a plus i got the Sikky intake manifold gasket it looks awesome
meet07
Is that one of those pimptastic Bov's from Japan?? Never seen it before? And why so close to the turbo since you have map sensor??
StricNyne
just was a convient location, and its a ARC Bov, i want to run the Steed SPeed BOV
Omni
it looks completely different from when i seen it sir AND WHERE IS MY HELP MAN I AM STILL WATING HAHAHA
Sil240
Car: Nissan S13 "The One Cam Wonder"
Los- She looks good!!!!
StricNyne
intake ports had a s*** load of coolant in them (cyc 5, 6) cleaned it up, installed thermal gasket. installed new headlights, i gotta do minor mods to corner lights ther than that it looks really good, pics coming once i clean her up, do corner lights, and wash and wax my baby !!
Omni
u need to come and help me finish my ccccccccccAAAAAAAARRRRRRRRR PLEASE
IM BEGGING RIGHT NOW SIR
StricNyne
what happen to it ?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Loving the progress man
StricNyne
ty ty, just found an oil leak form turbo feed line grrrr, got inside my heat blanket too :(, powder coated intake manifold also more cleaning, i need to change my plugs, some good pics incoming
