Strength of KA block?
275Performance
Car: motor building, turbo's,racing, photography, film making, music produciton
How much HP and/or boost can the Ka24de block hold? What's are its cylinder's made out of? Tried searching and couldn't get what I was looking for. Thanks for the info.
I'm building a drag civic and we resleeved its alluminum sleeves with steel cause they can't take much over 15psi really.
New to Nissans, just got a 240 for daily driver.
240marcuSX
Car: E34 525i
E46 M3
all the KA's are iron blocks, everything that I have read has said that sleeving them isnt necessary, and that the weakest thing about the bottom end are the ring lands.
Nathan
Currently the highest I've seen out of a KA block was 504rwhp, I suspect that number will jump to at least 600 relatively soon as there is nothing weak about the KA block, it's an all cast iron construction, cylinders included. Also, all the main caps are tied together with a girdle, which is a good thing :)
275Performance
Quote »all the KA's are iron blocks, everything that I have read has said that sleeving them isnt necessary, and that the weakest thing about the bottom end are the ring lands.[/quote] Really? Thats great to hear then. When you say bottom end, you mean the rods & pistons, or do they have weak cranks too?Thanks for the info.[
Nathan
No weak cranks (wow, there is about 3 threads talking about cranks at the moment!) the pistons are cast and hence, a little on the weak side (although there are people with 350whp on stock blocks). The rods are pretty sturdy as well, although for peace of mind I replaced both when I rebuilt my engine.
MECPInstaller
Car: installing stereo systems and minor performance upgrades
found a decent site awhile back that could help you out with doing a full rebuild on the bottom end http://www.ka24de.com
WDRacing
Yeah, if you look at the Sponsors list to the left, you'll see that KA24DE.com is one of them...heh.
MECPInstaller
lol sorry i'm not thinking tooo quickly damn green:) anyway wd this is off topic to this thread but how's the turbo kit coming along any info send it my way thanks [email protected]
bumpermatic
Nathan, do u happen to remember what thread it was that talked bout that 504rwhp? I remember reading it, but can't remember what the title was...it was on FA wasn't it?
<aside>Last I read a stock SR had just hit 600whp (sae corrected) in tampa, so looks like the stock bottom end sr vs ka (vs ca?) wars will keep on rolling...</aside>
BoostFab
Car: S13cp, S13fb, S14z
click here for the 504rwhp thread
cheers!!!
bumpermatic
thank you boostfed for the link...
question to WD, I know you had mentioned that you wanted to build the fastest ka24det. Do u think you'll be going for a dyno queen ka as well?
