Kinesthesia »
https://forums.nicoclub.com/kinesthesia-u3898.html
Wed Mar 17, 2004 3:37 pm
Before anyone grabs a flamethrower, I realize what I'm looking for is something of an oxymoron, catch22, whatever. However, I want some pussified coilovers ...
I would like to have a coilover suspension that on it's lightest setting is half way comfortable. I can see all the spring rates for coilovers but I keep hearing that it's "all about the valving" which is something that doesn't seem to be on any kind of chart.
I've been searching around, and I've found some information about Tein Flex coilovers and it sounds like you can replace the springs +/- 2 kg/mm which could give me coilovers with 4 kg/mm front springs and 3 kg/mm rear springs. I also sent an email to JIC, but I haven't heard back yet.
I don't know if coilovers have bushings similar to the spring/strut setup. So I suppose I might give up some drivability there. But what I would like is coilovers, something along the lines of a Eibach ProKit / KYB AGX feel at the low settings.
In case you are wondering why I don't just put Eibach/AGX's in my car, it's because I don't much care about the price difference and I would like the added adjustability that seems to only come with coilovers.
If anyone has gone from Eibach/AGX's to a set of Flex or other coilovers and could compare the ride for me, that would be ideal.
Thanks.
