Street truck ka....got lsd????
hessianben
I'm in the process of building a corner-loving daily driver out of an '02 KingCab 5speed with the ka24de motor. I've added a Magnaflow exhaust and a K&N in the box with a custom ram-air system routed from the foglight hole in the bumper. I'm about to swap cams (248intake,232exhaust) and intake/ecu from a donor s13, with lofty dreams of forced induction...
My question is: Where do i find help for the suspension?? drop spindles, rear drop, anti-roll, anything.... If anyone knows a good (or cheap!) supplier, I would be stoked!!!
Also, it would be great to have a limited slip in the rear. Is there a manufacturer that makes one for the Fronty, or perhaps better, a viable swap from another truck??(maybe even with rear discs?)
Thanks for any input!!hessianben
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
read the axle sticky at the top of this forum to determine what rear end you have. If you're lucky, you'll have a C200, and LSD's for that can be had through 4x4parts.com (Automotive Customizers). If you have the H190, start the search for a C200 axle out of a slightly newer truck.
