RatedR »
https://forums.nicoclub.com/ratedr-u4104.html
Tue Apr 05, 2005 4:21 pm
your toe is purely a directional angle, meaning it wont affect your ride's feel as much as camber. For camber, dont you think -1.5 in the front is too much? That'd tear up too much of your inner tire's tread...Remember, you want a street setup. Meaning you'd like to keep most of what little treadlife your 17 lowprofiles will have after you run them. If you're more into drifting, set the rear to about -0.5 to -1.0. the fronts shouldnt be set so high for the streets. If you're just a regular driver/grip driver who's not into slinging it sideways all the time, then about -0.25 in the rear would be good. Try -0.1 for the fronts, it should keep you planted even on hard turns.....
Performance wise, I'm not entirely sure about the figures I've given will suffice for your purposes. But I am currently in Wyotech and am in the Steering and Suspension class. If anyone disagrees, feel free to take their advice over mine. Remember, the settings i've given you are supposed to keep you from tearing up too much of your tread.
