Stray wire, and vaccuum lines. PICS
StryfeS13
Car: 1993 Nissan 240SX
IF anyone knows the order that these vacuum lines go in, it'd be greatly appreciated. I'm guessing it goes, white, yellow, pink. They connect right underneath the throttle body. Here are some pics for clarification.
And does anyone know what the hell this is? Or what it was...? Is it just a ground that broke?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I am not sure an I hate to sound like an a** but it might be in the service manual: http://Nicoclub.com/FSM
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
from left to right its suppose to be Yellow, white, pink. The wire is a grounding wire.
StryfeS13
Paul Wall wrote:I am not sure an I hate to sound like an a** but it might be in the service manual: http://Nicoclub.com/FSM
Haha, you don't sound like an a**, and I did check the FSM to no avail.
NISSAN240SX12 wrote:from left to right its suppose to be Yellow, white, pink. The wire is a grounding wire.
Thank you so much.
I have one other problem. My car is throwing a code 35 up (EGR temp sensor) But ONLY at idle, if I rev it to anything past 1000 it goes away, but the second it goes back to 650-1000 it turns back on. Possibly because the vacuum lines were wrong?
Maybe it's the ground that isn't connected? Can I just connect the ground to an intake manifold bolt where it connects to the head or does it have to go to a specific area?
zachattack_5491
Car: Pignose S13 Redtop SR
That ground is your injector ground.
It's quite possible that the messed up vacuum lines are causing the EGR to malfunction. You should post pics of where the hoses come from, never seen them color coordinated like that.
Edit: Page 8 of EF&EC you didn't look very hard.
Modified by zachattack_5491 at 1:28 AM 3/22/2010
StryfeS13
I did find that in the service manual actually, it's just I was looking for more of a color coded deal since mine is.
Can the injector ground go to the head? Or does it even matter
zachattack_5491
StryfeS13 wrote:I did find that in the service manual actually, it's just I was looking for more of a color coded deal since mine is.
It goes to the head. If you pull that wire towards the front of the car, it should line up with a bolt hole. Here's a pic from the FSM. It's not much help, but you get the idea.
allenms240
Car: 1991 Nissan 240SX
Zach knows the FSM page by page =D
