Strategic planning to keep a 92 Q alive (parts list)
kdkrone
I am at 130K miles on my 92 (purchased new) and have the same love/hate relationship as others. Presently I am in love, especially after a 200 mile run yesterday at 23.65 mpg (there must have been a tail wind)
Looking to the future, which parts should I consider for stockpiling and which just never seem to need replacing? The one motor that has failed has been the sunroof motor and I am aware of the transmission problem (I have had two replacements). I have, of course, had the chain guides replaced and have done routine maintenance as well as having all of the injectors changed after the second one failed 30K ago.
I remember reading a post years ago from Q45tech that sounded like he carries a spare car in his trunk (I believe there was a comment about how valuable is it to own a part if it is at home when you need it?)
So, those of you who plan on keeping your Q's for a while, and who have had them for a while, which parts fail (i.e., wiper motor, turn signal, wiper switch, other switches), which do you think you might need that would not be available in the future (i.e., MAF), which can and cannot be rebuilt (i.e., starter, transmission, alternator)? Headlamp assembly (because of lens fogging)?
Thanks for thinking about this.
Ken K
Modified by kdkrone at 5:45 PM 11/6/2008
Panther in a Q45a
Car: 1995 Q45, 1994 Q45, 1974 Pantera, 2006 Hummer
when you see a deal on a transmission, might be worth pick it up if you have a p[lace to store it.
look for people who sold there Qs and have a bunch of new or replacemnt parts laying around.
MAFwindow motors &/or regulators bose stereos and speakersmoonroof controls and motorgood R&P unitps hosesinjectersbrake master cylinder esp if you can find the big one from a 1990swaybar bushingsdriver seat - just replace the cushions as long as the seat motors workdriver door paneldriver door window controls might upgrade to wood grain if you like that looksteering wheel - or use a coverknock sensors & harnessturn lights and tail lights - old ones melt or corrode outstrutsradiator fan - old ones crackradiator hosesac compressorinside rearview mirror - the hinge comes loseclock - esp if you up grade to the gold oneignition modulswater pumpfuel pumpfuel pump control modulfloor matssun visorsECUTCUengine harnes
keep an eye on the classified section
Modified by Panther in a Q45a at 9:58 AM 11/13/2008
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Panther in a Q45a wrote:when you see a deal on a transmission, might be worth pick it up if you have a p[lace to store it.
look for people who sold there Qs and have a bunch of new or replacement parts laying around.
MAFwindow motors &/or regulators bose stereos and speakersmoonroof controls and motorgood R&P unitps hosesinjectorsbrake master cylinder esp if you can find the big one from a 1990swaybar bushingsdriver seat - just replace the cushions as long as the seat motors workdriver door paneldriver door window controls might upgrade to wood grain if you like that looksteering wheel - or use a coverknock sensors & harnessturn lights and tail lights - old ones melt or corrode outstrutsradiator fan - old ones crackradiator hosesac compressorinside rearview mirror - the hinge comes loseclock - esp if you up grade to the gold oneignition moduleswater pumpfloor matssun visorsECUTCUengine harness
What and how much of a difference does a 1990 Q45 Master cylinder make?
What is an "R&P Unit"?
ALSO I HAVE SOME OF THE ABOVE LISTED ITEMS IN CASE ANYONE WANTS SOME.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Gotta have the known good FPCU.
NICO ECU also.
Auxiliary ATF cooler.
New KS and harness.
All gaskets for IAC, EGR, TB, plenum, lower runners.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
i agree with that list...
I would say though to narrow it down a bit more, most important things to have spares of are injectors, MAF (always carry a spare MAF with you) and an FPCU. I like to carry things with me that I could potentially replace on the side of the road (an injector is a stretch).
Panther in a Q45a
R&P is a rack & pinion - your steering
the first q45s back in 1989-90 had a master cylinder that is 1/16" larger diameter. You may have to search the archives to find the info. When ever I look under the hood of a parts car, I always check for the bigger master cylinder.
Not much demand for them, unless someone is upgrading there Q brakes and wants the biggest factory brake MC available that will bolt on.
You need what Magic Johnson uses to stay alive after all these years with HIV: A whole lot of cash.
Stock up on the stuff that will get you a discount by ordering in bulk, such as filters. The rest, just acquire as needed, or try to buy a clean wrecked Q45 and put it in your back yard (or front yard for those of you in Arkansas).
rhinoone
Jesda wrote:Y(or front yard for those of you in Arkansas).
I resemble that!!
At least it saves time mowing the lawn...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Not an ungrde unless you change out the lines also.
Infinitiguy19
With stainless steel or 1990 Q45 lines?
I also have the rack, 4 extra MAF's and 3 FPCU including one in my trunk. LOL, extra set of seat controls, extra set of window motors, wiper motor, extra clock, and probably more all as extras for me,
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The fittings or routing to the ABS is different.
Infinitiguy19
Is there more of a difference in braking with the 1990 Q45 setup than there would be if I added stainless steel lines?
qship96
Car: 1996 Infiniti Q45
ppastos wrote:Is there more of a difference in braking with the 1990 Q45 setup than there would be if I added stainless steel lines?
the difference is tiny at best.....biggest difference is always the choice of tire, always.
