Nissan805 »
https://forums.nicoclub.com/nissan805-u180360.html
Wed Mar 12, 2014 4:14 pm
My original post is 3 years old, and I got rid of the car over a year ago. I sold it when it was somewhere around 233,000 miles, and the lady I sold it to got it over 240k. It ended up in a parking lot and got towed away, and is now in a salvage yard. As to your problem, I wouldn't trust any mechanic's opinion on it being the IACV. Go get second, third, forth, fifth, and sixth opinions, and/or diagnose it yourself. Usually when a mechanic diagnoses an electrical problem, it means that's the part that doesn't need to be replaced (with exception to some decent mechanics).
How do you know that what you're feeling isn't the car in a lower gear than it should be? The torque converter is supposed to lock up over 50 MPH or so only when it's at or near operating temperature; the fact that it isn't locking up at lower speeds is normal, regardless of operating temperature. Sometimes the torque converter on my J30 would never lock up, and it had something to do with the computer not seeing that it was at operating temperature. I'm not sure what sensor controls that, but it was probably going bad. If what you're saying is true, pertaining to the torque converter locking up over 40 MPH only when releasing your foot off the accelerator pedal, that's not normal. Are you saying it never locks up at all? The torque converter engagement is supposed to feel like a little jerk, but so slight that most non-mechanical people wouldn't notice it. It's not supposed to slip (in the conventional terminology) whatsoever. The RE4R01A has a turbine revolution sensor which not all transmissions have, and that makes shifting extremely smooth; it's supposed to slip a tiny bit.
From your description, this is not how the transmission is supposed to shift. I've talked to mechanics that I know about Jatco transmissions, and they all say that they are some of the best transmissions made -- bullet proof, reliable, dependable, durable. The J30 has some weak spots such as weird styling and a lack of headroom for taller people, but the transmission and engine were its strong point.
