maxnix wrote:Still no alignment data.
Steering box can be adjusted by technician per the FSM.
Unfortunately the situation has changed.
Well someone other than me drove the vehicle while I was in the process of fixing the brake hose. TOO %$%#$%#$ stupid to even question why there were blocks behind the wheels or why the brakes BARELY worked. Wheels weren't on tight. The "person" drove it to the dentist and the front left wheel fell off while it was parked. Luckily there was no real damage. Turning right (body roll to the left) makes the left suspension dip LOW compared to a left turn(body roll to the right).
So I finished working on it today... replaced another 5 lug screws gone bad, no real pains doing it this time thankfully!! I put some 16" rims on it with 225/60 tires. Alignment is totally screwed up and pulls to the right. I'm not going to do anything about it until i install an aftermarket suspension. The car will just sit on my driveway for now.
I have adjusted the steering rack pre-tension my lexus es300 before and it worked out perfect! But I'll leave this one up to the professionals.
For now I'll have the pleasure of relaxing in the 93 Q.
Does it cost a lot to check out the alignment specs? No point in throwing away $$ unless im going to get it fixed.
