theres only one relay, so i dont know what youre switching. between the battery and fenderwell on the d/s is where the blue starter relay is at.theother1wstolen wrote:i swapped the relays around, and it was still doing it and nothing else started acting up, ill take a second look at the relays and make sure i swapped the right one, and where exactly is that wire that your talking about a-ron? is on the steering collumn? and also, how is that if the problem is at the ignition, that the selonoid is getting power at all?
Phopson you are the designated "its you igntion" guyPhopsonNY wrote:
In other words... sounds like it may be more of an ignition switch problem
zerothread/332827
PhopsonNY was right all alongtheother1wstolen wrote:quick update, i just had some free time to check and it did in fact turn out to be my ignition switch, so im ordering a new one now. thanks again for all the help!
