rudee023 »
https://forums.nicoclub.com/rudee023-u4970.html
Sat Aug 07, 2004 6:04 pm
Your TPS sensor is not adjusted correctly. It should feel like it jolts back and forth like you are learning to drive stick, correct? Adjust the TPS by inserting a sewing needle or something similair into the middle wire of the three connecting to the TPS, do not unplug the plug. Turn the key to the second position but do not start the car. Get a voltmeter and ground the black probe to the negative battery terminal and touch the red probe to the needle. It should read 0.5 volts when totally closed and over 4.0 at WOT. You should see it climb as you move the throttle plate open. IF it is not set correctly then loosen the two 7mm bolts holding the TPS and adjust. Let me know if it works.
