strange sounds
vuta
hi guysi have a strange knocking sound coming from the front of my engine at idle. it comes and it goes. anyone know what this could be?:confused: thanks
DoriftoMania
Car: car
it might be the timming chain is slapping the timming guide or the valve cover.open up the valve cover to remove that piece of crap!:D
vuta
i dont need the timing guide then?
xekushnr
Car: '90 Nissan 240SX Hatch
not the top one or the right one.
vuta
oic i removed them and the sound is still therelots of tension on the chain , motor only has 90 thousand miles . i used a screwdriver to check where the sound is coming from.it seems to be coming from the bump on the front timing cover.could it be a bad gear where the distributer gear connects to the timing chain gear?
burnin240sx
does the knocking sound like a ticking? as if you had rocker arms?
