brainguyus »
https://forums.nicoclub.com/brainguyus-u96042.html
Wed Oct 22, 2008 6:55 am
No, I've not heard this particular noise as described.
Another possibility that comes to mind is your power steering. It's not uncommon for steering systems to display cold weather symptoms. I didn't mention this at first because you describe the sound as being under your feet. One thing to always remember is that cars are master ventriloquists. That noise could be originating from almost anywhere.
Make sure you check your power steering fluid. Also, have you added power steering fluid in the past?
Does the noise occur if you turn the wheel while the car is standing still?
When moving does the noise follow you all the way through the turn until you straighten the wheel or does it happen only while the steering wheel is in motion?
