Axoure Dragonkin »
https://forums.nicoclub.com/axoure-dragonkin-u19649.html
Sat May 01, 2010 1:27 am
I was thinking the same thing for the brakes. The wire could always be a different color than what I anticipated.
For the locks, weird isn't it. Does not bother me. The Viper install guide says this is how it is supposed to work so I'll trust that.
The remote start is set to voltage instead of tach (I just didn't want to tap a ECM wire). Don't think that would affect the main problem which is the key not cutting the ignition when remote started. Come to think of it... could the lack of a brake signal affect the remote start?
I could see that being the case...
Step 1... Remote Start
Step 2-Option 1... Brake pressed, Car shuts down.
Step 2-Option 2... Key turned to run position
Step 3... Brake Applied, sends signal to alarm brain to reset ignition
Step 4... Key turned off, car shuts down
I will recheck my connection for the brake this weekend.
