Strange Problem with JDM VLSD
Low330Coupe
Car: 90 KA-T Hatch
hey dudes...I have a JDM VLSD with the 5 bolt output shafts that I was planning on swapping into my 90 hatch that currently has a welded in it. My mechanic took the output shafts out (they came already in it) just to check that everything was good, and then when he went to put them back in, the longer shaft would go about 98% of the way in, and then stop. When it's pushed all the way in there's still like a tiny little 1cm gap.
Has anyone else had this problem/have a solution? I made some sweet MS Paint diagrams to show what I'm talking about. The first one is what it's supposed to look like (we're both actually not sure which output shaft goes on which side, please chime in) and the second is what mine does.
yes, I did a search and yes, I posted this on Zilvia too just in case.
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
Uh switch sides, there should be a lil keeper ring/or bolt that holds it in place that might be blocking it
Low330Coupe
Car: 90 KA-T Hatch
do we have the output shafts backwards?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
No,.they are on the correct sides.
night_krawlers
Car: s15
recheck the clip rings
