BoyWonder »
https://forums.nicoclub.com/boywonder-u12909.html
Mon Mar 01, 2004 4:24 am
Been looking to buy this automatic 240. The major problem it has is that it will not go into gear at all (at least, I couldn't get it into gear). You can push in the button and change it to drive or reverse or whatever, but it won't move. No sounds or anything when you do that, either. Did a quick search and didn't see anyone else having a similar problem, so no idea what to check. I haven't checked for codes. I guess my big question is this; is there any way to diagnose this as a mechanical or electrical failure with some other minor testing? If it's a mechanical problem, I have a working used auto transmission I can put in til I get all the stuff for a 5 speed swap. I mentioned the electrical part also because there is some serious corrosion on the battery, which could be an indication that there's a short somewhere which could somehow be effecting it, though I'm not well versed in all things car so I have no idea outside my newbish speculations. Also, this car has been sitting a few months short a year now, so please take that into consideration. If the guy accepts my offer, I'll have the car at my house so I can test more then. Thanks for the :help
Edit: The guy selling it claimed that prior to it's complete failure, it would shift until it warmed up. Figured that might be an important bit of info to include.
