s13sr20chris wrote:ok two poss issues.one is the revlimitier. if you cant rev(in neutral even) over 2000 and some change rpm, then there is some prob with maf or maf circuit. the ecm is in maf failsafe mode.one is poss auto trans issue. if you can floor it and car just creeps off you may be stuck in 3rd gear. if ecm/tcm see certain probs the trans will go into a/t failsafe which is really just full mechanical mode with no electronic control. mechanically you have 3rd gear and reverse.
well right now its working fine and the problem pops up randomly but I think im going to fix all the possibilities of the problem just to be safe and hopefully never see the problem again and ill see how that goes.
Sorry if this is a noob question but how do you look up codes for the car? I went to local autozone and asked if they could and they said only for cars 96' and above. -_-
