wanna.be.fast »
https://forums.nicoclub.com/wanna-be-fast-u24219.html
Wed Feb 02, 2005 10:38 am
Im having a strange problem and I don't know what it is exactly. I have an Sr with vspl intercooler, BOV, profec BII turbo elbow, downpipe and exhaust etc...This is the scenareo.
Ill be driving and floor the pedal in second and reach my desired boost set on the profec B. If i do the same in any higher gear, at around 3500 or so rpm the boost will go up to the set boost then once it rises some more rpms (700 or so) it suddenly falls down to .54 bar or so which is stock boost off of the wastegate. What could be the problem? My settings? I figured if it was a vaccum leak or boost leak the car would run and idle like garbage right? Well the car idles and runs prefect untill this happens. With the boost controller off it doesnt have the little studder or anything and just runs off of the wastegate which is to be expected. What could be the problem?
Thanks in advanced.
-Matt
