qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Tue Dec 18, 2007 12:21 pm
Today,I went to get a few simple things done on the Q at the little local Japanese auto repair shop that I occasionally use for basic services.I was charged $15.00 labor to install my Redline oil/Infiniti filter-quite reasonable,especially since I can chat with tech during process and be sure all the bolts are replaced on engine sheild!
Here is where it gets strange! They charge $35.00 labor to replace Differential fluid {my redline} Seems like an easier job than the oil/filter/sheild process above to me,but whatever-got it done.
I had the 2 exhaust mounts and upper links in the same box with the motor oil & gear oil-tech asked if I wanted quote to install-I said sure,owner says $75.00 PER LINK,and $50 for exhaust mounts! I tried to explain that both should take less than 1 hour total,especially since car was already on the lift-no go,he wouldnt budge-nor would I
After oil/diff fluids were done-paid the $50.00 and drove to a little service station that I get fuel from {Sunoco} and had both links and exhaust mounts done for total of $80-which I thought was reasonable-it took them all of 65 minutes from on to off lift....including taking a few phone calls!
