After applying belt dressing on the power steering belt to quieten a reoccurring belt squeal I decided to replace all belts. The belts looked to be in good condition but I bought new belts then removed the front passenger wheel and started replacement work. In the process of replacing the belt, I noticed the crankshaft pulley was actually rubbing against the power steering belt. What the heck?
I took my hand and pulled the crankshaft pulley apart and somewhere in my memory though about the Maxima/I30 crankshaft pulley separation problem. The crankshaft pulley had separated from the harmonic balancer and drifted back against the power steering belt. Yes dreaded crankshaft pulley separation was happening to me.
It looks like I can get a new OEM pulley for
$254.81 that is $103.96 off the list price of $358.77 I found an aftermarket version for about $198 but for the small money difference I will stick with OEM.
Here's a thread about the problem.
post6219014.html?hilit=crankshaft%20pulley#p6219014
Here's a video I found to demonstrate the problem.
[youtube]
http://www.youtube.com/watch?v=7lXTdZMc ... re=related[/youtube]
