Strange Pictures!
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
71-521
Here's a strange sight I came across today:
[img]http://i19.photobucket.com/albums/b169/ ... 05355a.jpg[/img]
here's a pict of where the second one goes into the block:
[img]http://i19.photobucket.com/albums/b169/ ... 05356a.jpg[/img]
ok..any one know why some one would do this????
IMH
[user=4]71-521[/user] wrote: [quote]Here's a strange sight I came across today:
ok..any one know why some one would do this????[/quote][quote]That's a JDM engine.  My J16 had that extra dipstick hole in the block.  They had a different oil pan depending on which vehicle they were put in.  Looks like someone chaged it over to the E1/J13 dipstick and oil pan/pickup and left the other one in also.  I just plugged the extra hole.
[/quote]
Victor Laury
The L16 in my truck (which is not the original motor) also had this extra stick port. I cut it short and crimped it over.
71-521
Thought so...another great find with this was the W53 closed chamber peanut head!
And in great running shape!
Not bad for $40.00, huh?
kenbagby
Ok, now you're going to have to explain the "peanut head" comment!:)
PS, I've emailed the support board to find out if we can add more than one picture to each post. Did you create this post first with both pictures then cut and paste? Ken
71-521
Ken:
I actually posted the pictures via photobucket so that more than one can be in each post...now, about that peanut head...here's what I have:
[img]http://www.worldaccessnet.com/~dcmurphy ... er_336.jpg[/img]
Kinda looks like a peanut in a way, huh?
versus the normal combustion chamber here:
nice huh? higher compression with the closed (peanut) head...
Oh, and thanks to Bre620 for the pictures of these heads he has posted on his board:  the620.com
phatdave
The blown L16 in my project '73 620 has the W 53 head....guess I should pull it and keep it huh?....Dave
IMH
[user=91]phatdave[/user] wrote: [quote]The blown L16 in my project '73 620 has the W 53 head....guess I should pull it and keep it huh?....Dave[/quote]You say that it has blown the head gasket twice.  If is was surfaced both times it might not be worth keeping depending on how much was removed.
phatdave
Nah..two different engines...the original  blew gasket years ago...and the guy I bought it from, now that I think about it said he thought he washed out a piston,not blew a gasket...thanks
phiz
Check out the mill in this Datsun:
phiz
Pretty sweet ride....
Pac. coast Datsun
I believe the forklifts came with the j 15.
IMH
The C, E, E1, and J series engines were all used as forklift engines.
djmoreron
dont those things run off propane instead of gasoline?
71-521
Yup
naSTy720
[img]http://www.olddatsunpickuplovers.com/at ... php?id=662[/img]
i know this isn't the exact place to ask this, but is there anyone on here who can help me with some tech questions i have about these beasts?  my shop uses a 1980 TCM forklift with one of these engines in it and it has some HORRIBLE cold weather starting issues...the propane setup is really primitive and i'm not sure how to remedy the problem...i can address it through PM if someone could just point me in the right direction...thanks in advance!
Return to “Datsun Chat”
