Rickedl »
https://forums.nicoclub.com/rickedl-u168038.html
Sun Sep 12, 2010 10:49 am
Car specs; 91 240sx le hatch.
Everything is stock or oem replacement
Recently replaced battery and alt.
126k miles
Obviously the car hasn't driven that much in its life. I picked it up last winter (Jan and live in Central Il) and as I was driving it home It started to get hot. But it didn't overheat. I let it idle for a few minutes and it went right back down to Operating temp. Have had no problems until recently. August I notice it is getting hot on me again, here is the cycle it goes.
Start up.
Start driving it goes to Operating temp.
After about a minute it goes to just under H.
A few minutes later it returns to Operating temp.
If the car does not cool down to cold it will work fine, if it does start over at top.
I have just replaced the thermostat with a KNOWN GOOD stat.
I have no leaks,
Fans work just fine and the fan clutch is just fine.
The only thing I haven't chanced is the water pump and the radiator.
I would go after the water pump but after it gets hot it works just fine.
Thank you for your help.
