GX470 »
https://forums.nicoclub.com/gx470-u211542.html
Thu May 08, 2014 1:06 pm
A little bit of background: I have an '04 Pathfinder SE 2WD with almost ~175k on the odometer. Been a very great & reliable car since I was able to made it up to that mileage from ~4k with only basic regular maintenance and no major issues or repair whatsoever. Aside from periodic oil change, some other services include air & cabin filter (changed every year), drive belts, tires & brakes, battery, spark plugs (changed at 100k), 2 up-stream O2 sensors (at ~160k) and all the fluids drained n refilled every 50k (coolant, transmission, brake, steering and even the differential). That's about it. Everything else is still original up to this point.
Here comes the issue. Everything had been fine until the other day while I was driving with the AC on, I noticed the temp gauge started climbing up. Didn't let it go all the way to the max, I immediately turned off the AC, put the heater on full blast. It did help bring the temp back down. Pulled over and checked under the hood, coolant level was normal, no leaks anywhere, fan was turning and no strange noise.
Went home and did some research and troubleshooting. New thermostat, radiator cap, fan clutch (all dealer OEM parts) and a complete coolant flush (even though, I already did that at 150k). All the above didn't seem to fix the issue. I don't think the radiator is clogged because I notice engine runs fine for the first ~30 mins before overheating. Doesn't matter if idling, in traffic, or on freeway. I don't think the head gasket is cracked either since the fluid was very clean when i drained it out.
This issue is very strange from what I've read about overheating. Now, I'm really lost and don't know where else to look for. Any opinions or inputs would be very appreciated.
