lci240sx »
https://forums.nicoclub.com/lci240sx-u27802.html
Tue Apr 12, 2005 4:04 pm
I've done a search and have been unable to find information concerning my issue so hopefully someone out there has some insight on it!
I'm running a '93 240SX HB KA24DE with 5-spd manual and I am having serious overheating issues. I have tried all the normal stuff like putting in a new thermostat, drain and flush the coolant, tested the engine temp sensor, etc. The radiator is a brand new high-flow Koyo (and was installed before the issue came up anyway but I'm just helping eliminate pieces of the puzzle).
General Symtoms: When shifting between 2nd thru 4th, engine temperature climbs rapidly and then settles back out when up to interstate cruising speeds of 65-80 MPH. I am unsure if the vehicle speed sensor is totally functional to control the radiator fan properly, but the fan only runs when the AC is turned on (which indicates that something is wrong between the temp sensor and the fan itself, I am only bypassing certain relays and ECCS controls to run the fan at all by running the AC). Basically the troubleshooting tree points to ECU, Radiator Fan, Fan Relays 1-3, and/or headgasket in the process of failing.
The car also has a rough, semi-seeking idle when the AC is on and a stutter problem when given approx half throttle during acceleration. This also points somewhat at the ECU (which could be retarding or advancing timing causing engine overheating?).
Does anyone have any information that might help me figure out exactly what is wrong?
Thanks in advance.
edit: My appologies for missing the sticky and posting in the inproper forum sub-section, please move if necessary.
