Cody240 »
https://forums.nicoclub.com/cody240-u138281.html
Sat Jun 05, 2010 9:40 am
Ok so about 2 months ago I was driving my car and then noticed some steam coming from my hood so i pulled over and shut it down, then popped the hood and see my water pump pulley shaft had broken and it was just sitting there. So I get it home and buy the replacement water pump and install it, not long after it starts to over heat but not in the normal way one might think it would sit there and be fine for a good few miles then it would suddenly start to heat up and then try to overheat then I would shut it down. Next I checked the thermostat and it was going bad so i changed that out hoping it would help, well it helped a little but it still had the problem. Now by this time I could only think of a few other things that could cause it, 1 the system is not bled and there is some air in it, 2 it has a blown head gasket and it is pushing air in the system, 3 it also may need to be flushed. Well I flushed and bled the cooling system and it helped again just a small margin but still would do that weird overheating. So I next got a compression tester and tested all the cylinders and found that the third cylinder was about 30 psi lower than the rest which were all at 120 give or take a psi, so I took off the valve cover and checked the torque on all the head bolts and it turned out that the ones on the exhaust side were about 15 lbs under spec on that cylinder and a little less on the others so i torqued them up and it seemed to fix the problem. Now I after this I had to go some where about 45 minutes away and it was the only car I had and it drove great almost half way there, about 20 miles then it started doing the overheating thing again but this time I knew what the problem was and pulled over and relieved the pressure in the radiator and then blasted the heater and stopped and repeated the process of relieving pressure all the way back home on side streets (because I was out of tows form AAA) and managed to keep it from over heating at all. So now we are at were I am today I know it is my head gasket and have this head gasket sealer to try and fix it but I wanted to come on here and ask the minds of NICO what they thought. Any info would help thanks. Oh and the engine is a single cam btw.
