Gladius »
https://forums.nicoclub.com/gladius-u6698.html
Sat Aug 21, 2004 11:31 am
OK got under the car and spayed that hoe with cleaner and got rid of all oil traces. I found that plate your talking about, you said its on the bottom front of transmission, really its on the lower oil pan facing the front of the motor. But thats not important. I am going to open it up tonite.
After driving it around for 20 mins and came back, I quickly jacked it up to monitor the situation. Immediately oil starts to drip. Now exactly where its coming from is hard to tell, because I believe a little bits drips as I am driving and it gets throw around by the wind. Upon inspecting the outside of transmission housing, no oil is present on the sides, its all originating from the bottom of the motor/transmission.
The little hole on the bottom of the transmission where it meets the motor is where I think its coming from, but the weird part is, the oil comes out black when i just changed my oil 2 days ago. The oil on the dipstick is yellowish clear. I guess the clear oil runs over the crap in the bellhousing and gets polluted.
I checked around the turbo drain area and no leaks were found. Its def. coming from within the flywheel/bellhousing area. So its safe to assume that my 4 day old rear seal is bad or was installed incorrectly. Anybody have any personal experience with installing this seal? Is it really this touchy?
