Arrow »
https://forums.nicoclub.com/arrow-u15687.html
Fri Mar 18, 2005 4:55 am
As long as I've owned my 240 (3 years now) I have had an intermittant noise that comes from the rear of my car when I go in reverse (not just when the car in in reverse, but even when it rolls backward). I have a 1990 with around 175k miles. When I first got the car I had the pads and rotors replaced at a shop. And I just recently (past month) replaced the pads, rotors seemed fine. The noise seems to be a cluncking/grinding noise. It seems to come from the passanger side rear tire. The noise is a little weird on when it occurs too. Sometimes there is no noise at all. Other times I'll be in reverse and there won't be noise until I start to brake. And yet there are other times when it makes the noise until I apply pressure to the brakes! The only thing that I can think of is that the pads are catching or something strange like that...... Thanks in advance for helping me! If you need any more info I should be able to provide it, but I am currently at college and don't have my car with me, so I won't get to actually attempt to fix much until next weekend when I'll be home for Easter. I just want to try to get ideas and possible solutions before I go home so that it might be easier. Thanks again!
