Strange noise when I start the car cold...
General discussion area for the L30-chassis Altima
atl530i
Car: 1994 BMW 530iA
2001 Nissan Altima
Hi,
When I start my car, it makes this screeching noise when cold and it is not as loud when it is warm. I was wondering if anyone has had the same problem and knew what it could be.
I already searched and came up with more belt noises then anything. But when the car is running, there is no belt noise. It is something else i guess.
Thanks.
Justin
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
Justin,I would start up the car, pop the hood and try to locate the source of the noise. Typically screeching noises are systemic of belt tension/alignment problems. You might want to check the water pump or the alternator to make sure they are not producing the noise.
atl530i
Car: 1994 BMW 530iA
2001 Nissan Altima
I did that with the wife turning the key. It seems to be coming from the distributor cap area. It has a warranty on it so the dealer will fix it.
edalejandro
Car: Nissan Altima 2000 GLE
Justin,
If you have not traced the screeching problem to the drive belts or the water pump or the distributor or the alternator, try listening to the idler pulley at the center of the drive belt system. I have replaced the unit in my Altima 2000 several months ago with the same problem.
Edalejandro
atl530i
Car: 1994 BMW 530iA
2001 Nissan Altima
Thanks,
I figured it out. It is coming from the belt drive. It just echoed like it was coming from the distributor. But when I was in the car, it was coming from the right side. I'm going to mess with it this weekend.
atl530i
Car: 1994 BMW 530iA
2001 Nissan Altima
Fixed.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
What was it? My SR20DET occasionally does it. I have a feeling my belts just need tensioning.
atl530i
Car: 1994 BMW 530iA
2001 Nissan Altima
I tightened my alternator belt. Still has some slack in it so it is not over-tightened though.
Return to “2nd Generation Altima Sedan (1998-2001)”
