Strange noise upon ignition
SrS13
Car: 1990 Fastback, 1993 Convertible Coupe
My Sr just recently started making this strange noise as soon as it ignites. Its like a Squack upon turning over??
anyone know what it is? or what it means?
I have a red top Sr in a 1990 240 stock setup
thanks for the help
nrcooled
Car: cars, duh
We definately need more info on the "Squack" that you are reffering too
SrS13
it seems to turn over slow but as soon as it catches it squacks sounds like its coming from the starters side but im not sure
nrcooled
Car: cars, duh
Well I was an idiot and pushed one of my retaining bungs on the flywheel through to the teeth and I get a clicking noise at start up (from the starter hitting the bung that got pushed through).
I would check your starter
SrS13
but would make such a strange noise? would it need to be replaced?
my noise is no where near a click
f8sjester
did you check the tension on your belts? extremely loud squeeling noises on start up are usually slipping belts
MojoMan
Car: working on cars and women
I think I know what sound your talkin about. It definitly sounds like your starter. Have you checked to make sure the starter bolts are on tight. that sound can normally be heard when the starter is binding up on the flywheel. You might also be missing teeth on the starter or even the fly but I doubt that. Just check your starter and even pull it off if visually the starter is good and you cant tell. But it definitly sounds like it is binding. If the short and vague description you gave of the sound isn't the starter then when go from there.
AllTurBo
Car: 94 red drop top w/SR
is it like the sound that happens when you try to start a car that's already running?
SrS13
nope it is nothing like that sound
its more like a goose is being tortured by my engine
quiksilvia
Car: 95 s14 se
you have quite the imagination
