flattire »
https://forums.nicoclub.com/flattire-u52285.html
Mon Dec 18, 2006 6:22 pm
Ben,
Higher revving when cold or going up a grade is understandable. I’m talking about flat ground and a noticeable jump in revs from say 3000 to 3500 rpm. So much so that you really feel it. Now, of course, this is an automatic with a CVT transmission, but the problem feels as if you were cruising on the highway and had a standard transmission and you quickly pressed the clutch in and then let go again. If you did that, the revs would jump and you would loose power momentarily until the clutch engaged again. That is what if feels like.
I am mystified. I have no idea if it is the transmission, injection, fuel pump, the high tech electronics or something else. Personally, I suspect the transmission as per the above analogy of a standard transmission – but I am no mechanic. Strange, but around town it’s OK. The problem seems to be only on the highway after about 10-15 minutes.
I took it to the dealer and they have no idea. They said if they cannot reproduce the problem, then it is next to impossible to diagnose. Great.
Flattire
Modified by flattire at 8:36 PM 12/18/2006
