Justinians_2:40 »
https://forums.nicoclub.com/justinians-2-40-u122224.html
Wed Oct 27, 2010 4:52 pm
First of all, I'm confused by what you mean when you say you get a drop in vacuum, do you mean the vacuum increases (gauge goes to left, typically) or your vacuum decreases (gauge goes to right, typically). Also, vacuum is not usually given in psi, it's usually given as in-Hg or something along those lines, unless your gauge reads absolute pressure instead of relative pressure, which is unlikely.
Also, it's typical for an engine to run lean at low/no load (idle), this depends on the tune of course, but if it's the stock tune, this should be normal.
