The car was fine all day, and then all of a sudden there was a faint knocking noise comming from my engine compartment... It is only when the motor is revving, wether the car is moving or not. I don't hear the noise at idle though. It sounds kinda like the ka valve tick, but more of a knocking noise instead of a ticking. You also have to listen pretty closely to hear the noise unless you are inside the car..
A friend of myne is pretty good with sr20's and he put a listening device to my block and my head and he said that he doubts it is rod knock, but he isnt sure where the noise is comming from...
Also, recently the turbo seems a bit louder.. I installed a blitz blow off valve the day before the noise started, and the day of the noise i had raised my hood... i hope that helps diagnose the problem....
could someone please help?
