number 1: the timing. i have everything set according to the FSM. piston 1 is at TDC on the compression stroke and the dizzy is lined up with #1 correctly. when i start it, it runs but sounds like a lawnmower. then dies when i give it gas. i have to advance it all the way to get it to run.
number 2: the exhaust temp. i had it running for 20 seconds and the exhaust header got incredibly hot. to the point where i dripped some water on it and it evaporated immediately. like i said, it was only running for 20 seconds.
number 3: the interior electronics. nothing works. cluster lights, interior lights, blower motor, headlights wont go up, wipers. nothing. it sounds like i blew the 75a fuse, but everything is how it should be on the alt. the plastic insulator is there and everything. heres where it gets weird. everything turns on the second i depress the gas pedal. watch.
[youtube]http://www.youtube.com/watch?v=fO1SNXF75V4&feature=plcp[/youtube]
i dont know what to do for any of them. ive checked all the grounds and fuses. im gonna replace the 75a fuse just because. but other than that, i have no idea.
