SteveTheTech wrote:That sounds like an AAC valve issue. If the idle speed cannot be controlled due to dislodged carbon in the linear solenoid assembly you idle will tend to be erratic.
My shop installed a brand new IACV from Infiniti, I saw it 1st hand, brand new in the Infiniti parts box with a new gasket.
After IACV replacement, the TPS was set at 0.52V & the IACV was set to FSM specs for idle RPMs with the car fully warm w/ TPS disconnected. FSM manual instructions were then followed to "RESET IDLE POSITION MEMORY" (page EC-74)
Unfortunately I still have the same problem. The car will be idling fine in drive with foot on brake & then suddenly stall. If I see it happening I can put it in neutral & feather the throttle to catch the rpms from dying. Then rev the engine to 2000 rpms for about 30 seconds & then the problem is gone. At 2000 rpms the engine is running nice & smooth as normal.
Things replaced/fixed last 7 months (108,000 - 114,000 miles) that could affect idle:
Full timing belt kit w/ all belts & idlers (7 months ago)New OEM NGK Spark plugs (6 months ago)New OEM Throttle position sensor (7 months ago)New OEM IACV (last Friday)New battery (last Friday)Cleaned MAF (last week & 5 months ago)New air filter (2 weeks ago)New fuel filter
I have been using Shell 93 octane gas for about 5 years now EXCLUSIVELY. About every 3 months I use a fuel system cleaner & have been doing that since I have owned the car from 39,000 - 114,000 miles. The last 4 bottles of cleaner have been Redline S1.
Anyone have any suggestions?
Modified by J30inthe sun at 8:46 PM 4/12/2009
