qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sun Jan 04, 2004 10:21 am
[QUOTE]Originally posted by Q45tech "]The coolant temp sensor [the 2 terminal one] only throws a code when fully open or fully shorted [say zero to 40 ohms] .........the normal range 325 ohms at 176F to 2500 ohms at 68F..............if connector corrosion made it read 5,900 ohms [normal for 32F] the ecu just thinks the engine is cold and increase the rpm to warm it up.
1990-1995 ecu are dumb as rocks.....they do what the sensors tell them to do with out checking unlike modern OBD2 systems.
Q45tech,my q is a 96,with OBD2,would this problem with 1200rpm idle throw the check engine light on?another symptom I am experiencing with the fast idle is that the transmission seems to be holding upshifts till much higher in the rpm band for the amount of throttle given,compared to before this idle problem began!It wont even go into 4th gear till about 45mph,even with verry lite pressure on the accelerator,never had this happen before,HELP!!!!!!!!!!!!
