Strange Idle problem...
CaelanSeth
I know there are several posts on idle problesm but I could not find a solution. OK so my car is a high mileage (225,000 miles) 1989 240 auto. Last week it idled fine, if maybe a little low.
I changed my belts a few days ago, while I was at it I sprayed a bunch of cleaner in the throttle body and cleaned the plate.
Put belts back on and everything seemed good, except I noticed the idle was very high when I put it in park or neutral. And when the car gets warm, the idle rapidly bobs up and down from around 1700 to 1200 rpm. I first tried adjusting the screw, it had no effect. I figured the cleaner in the TB pushed a bunch of gunk into the IACV, so I tried cleaning that.
When its in drive it seems ok, except when i let off the gas it seems to drop rpms very quickly, but that coulkd just be my imagination.
I removed the IACV and cleaned it out real well, there was a gasket between it the the TB that broke so I put it back on without it, as many people have said their cars dont have the gasket. Anyways, I wasnt sure where to position the brass screw so i just screwed it in quite a ways, put the valve back on and my idle is worse, now over 2,000 rpms.
I pinched the air regulator hose to see if it would drop, it didn't. Disconnected AIV, but it had no effect. I cannot think of what it could be, except a leak possibly somewhere in my intake, the rubber bellows that connetcs to TB is old and a little cracked, but i dont know and have no idea why it started when I changed the belts... any one have any idea?
r3v_v3ng3
Car: 91 fastback ka-t
check your coolant levelback out the brass screw in the iacvloosen your throttle cable and see if it does anything
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
put it in base timing then adjust your iacv and that should do it
