Strange Hesitation KA24DE
AxiS14
Car: 1995 240sx
Car runs perfectly fine before it heats up. After awhile of driving is where the fun begins.... 1st gear is ok....2nd gear starts to lag/hesitate as if i was about to start boosting...It kind of feels like im hitting a flat spot on my tps but then it clears out above maybe 3200-3500 rpms, but then i lose power at about 5000 rpms. 3rd gear does the same at low rpms, but 4th and fifth gear or fine.
I have replaced my MAF, Replaced an injector o ring, cleaned the fuel pump sock, replaced my fuel filter, all new plug wires (still old plugs). The hesitation is hard to explain, The car shakes somewhat as if the differential was locking up or the gears in it were clogged up, Then it jerks and "free's" itself. Hopefully i can grab some help from you guys... Things I'm going to check is the grounding to the car because it appears that im losing ground. Also maybe change my spark plugs. DO you guys suggest i compression test the engine? O and 1 more thing the hesitation gets way worse once i turn my AC on which is why i think the grounds are messed up. Thx and sorry for the length, im planning on going KA-T soon and i would like to figure this problem before. I may end up just getting another motor all together.
7anshin8r
Car: 96 Nissan 240sx
You really gotta search or the dogs will find you and tear you a new one.
That being said everything you described sounds like a normal KA24DE. Mine does the same. I think I read somewhere the KA reaches it's power peak somewhere around 4.5k RPM.
If your going to go KA-T I would suggest the KA-T section of the forum (zeroforum?id=170), they can give you a lot of information on what these motors like/dislike on boost. You will most def. will want to do at least a compression check. A quick search will give you much information on what your compression should be and what is acceptable.
Hope you have good luck with the KA-T.
