patrickm1587 wrote:My wife has a 2006 Maxima, v6, auto. It only has around 63,000 miles on it. The strange thing is that when you come to a stop, it stops putting out heat. If you're moving it works fine. It doesn't make a bit of sense to me... Anybody got any ideas?
Patrick, it's a very common problem for the 6th gens. The design of our radiators, and overflow tank sucks and air bubbles get mixed in with the coolant. Hence while you are running and coolant is circulating the heat works flawlessly. Once you stop, the air bubbles block the coolant from flowing freely.
Some of the 6th genners park their cars on a steep hill so that the radiator cap is the highest point in the coolant system, then rev the car up until they "bleed out" all the air. Personally, I have had success with this method once (60k mi) but now it failed (140k mi). You can get a coolant flush done for $50-60 and it will solve the problem, which is what I'm doing now.
Hope this helps.
