tenkawa_akito wrote:Alan, with the SPL rear toe arm parts, would you recommend an alignment shop install and set them or could any joe schmoe pull the old arm, use the original to gauge where to set the new one and reinstall it?
Also, ho exactly does it eliminate dynamic toe change? is it because it doesn't have rubber bushings that can shift?
For toe I would highly suggest an alignment shop, a very small amount off and the toe will be off enough to cause a pull, wear out tires, and/or handle funky. Plus when loaded you have to keep in mind that the OEM arm absorbs some load into it's bushing by compressing it. You won't be able to accurately gauge how much compression is in the bushing under standing load and this will make your toe off as well.
As far as dynamic toe change, it's very hard for me to describe without a visual.
Here you can make out the RUCA, Traction Rod, and the Toe Arm is hidin behind the brakes.
Basically when the suspension compresses, the arms are not equal length so you will get a twisting force in the suspension and this is what creates toe-in under load to stabilize the car under acceleration, and when cornering.
However, when you increase the length of the traction arm in relation to the toe arm you end up with greater equality between the two which reduces dynamic toe change. If you can prevent excessive toe change in the corner you can improve the pivot ability of the car and thus the steering response and overall handling can improve.
