Strange engine noise during cold starts
DarkGreenQ45
I have a 1997 Q45 with the 4.1L engine and during cold starts the engine makes a horrible grinding sound for about the first 5 minutes. After its warmed up the sound goes away and everything is normal. It only happens when the engine is completely cooled down. Does anyone have any theories???
qship96
Car: 1996 Infiniti Q45
oil level and condition? when was the last time oil was changed and what weight oil was installed? Sounds like it could be oil starvation since it only happens after cold starts.
Mint Q45A
Car: 1994 Q45A
And make sure you are using a good quality oil filter (OEM, or Mobil1)....
Trumpkin
Car: 1995 G50
It could even be a bearing. Idler pulley bearing, waterpump bearing, alt, but you would think the noise would stay. How many miles do you have on itt?
Jim1999Q45
Car: 1999 Infiniti Q45 2006 Lexus IS350 1992 Toyota Celica 2000 Ford Ranger
Are you sure the starter motor is disengaging after start?
SleepinTXQ45
Car: 1994 Infiniti Q45
i would agree with all above, but.... if u can take off the accessory belt(drive belt), if noise still there, internal, & not saing possible but i have never ever seen a starter hang up for 5minutes&/or warm-up, but anything is possible, so start their
Q451990
Trumpkin wrote:It could even be a bearing. Idler pulley bearing, waterpump bearing, alt, but you would think the noise would stay. How many miles do you have on itt?
I second this theory... I had an idler pully on my old Q that would howl like a Ford power steering pump at startup. Very loud and annoying... but would go away. Far worse at cold ambient temperatures.
I would get a mechanic's sthesecope to narrow it down. They are dirt cheap at Harbor Freight (www.harborfreight.com) - especially you have a local store and get on their coupon list.
Heath
