I was moving some stuff in the back of my garage and decided to use my G35's high beams to light up the work area. (Some other info: car was partially backed out of the garage -a partial incline with the back lower than the front- and turned off. Lights were on -fog and high beams set- and key out of ignition. Temperature was about -5 Fahrenheit)
Moved the boxes for about 5 minutes, got back into the car and took off the high beams, followed by turning the lights off. This is where it starts to get weird.
I noticed that the center console lights were still on and then looked up and noticed part of the garage was still lit.
Upon inspecting the situation: The interior lights were still illuminated (center console, clock, dash at reduced brightness), the driver side headlight had the parking light on, and the passenger side light had the high beams + standard + parking lights on... tail lights also on.
I attempted to start the car at this point, but the lights dimmed and the solenoid failed to engage (not one turn over). Then randomly the high beam + standard lights on the passenger side turned off. So center console, clock still on, headlights on parking lights, and tail lights still on. I toggled the light switch several times in every possible orientation to no effect. I leave it set to all lights off.
I attempt to start the car again, there is no crank, but if I hold it in the starting position, after about 5 seconds all the lights begin to dim until dark. Releasing the key returns all lights to normal brightness. At this point I'm wondering if the computer that controls the lights shorted and then drained the battery. I attempt ignition probably 3 or 4 more times. Same result. I get out and use the key fob to lock the car. Doors lock, but locking "honk" is barely audible (appearing like dead battery).
I check on it after 5 minutes, lights still on. After 10 minutes, lights are out. I press lock on the key fob and the honk is loud like normal. I unlock the car, get in, and start it. Starts up quickly just like normal. Lights act normally upon testing. I let the car run for 5 minutes. Turn it off and start it again. Everything normal. I have now driven it twice since - all normal.
So... is this just a fluke?
Hopefully a one time thing,
Lars
