Strange Electrical Problem...
Sursa
Very rarely my car will not make the clicking noise when I flick on either turn signal. The lights, front and back, still blink when this happens but it usually goes away after turning the car off for awhile.
The other day I had this happening all day. After turning the car off and letting it sit for awhile and trying again, I still had no clicking sounds.
I'm not too worried about the absence of the clicking sound from the turn signal as I am the other problem, which seems to happen very randomly when the turn signal problem is happening... When I turn off the car and take out the key, I hear this buzzing sound. Its kinda loud and sounds like its coming from behind the gauges in the dash! When i put the key in it goes away. I can start the car ok and usually when i take the key back out it doesn't do the buzzing sound again.
Any ideas guys? Really strange problem.... Its a 03 Sedan, 6MT
infinititech1
bulletin on the buzzing noise...not sure of the number
Sursa
infinititech1 wrote:bulletin on the buzzing noise...not sure of the number
Good call After further searching I found:
Component Description:17. ELECTRICAL SYSTEM Bulletin Number: 03055 Bulletin Date: FEB 2004
Vehicle: 2003 Infiniti G35 Summary:BUZZ SOUND FROM METER CLUSTER AFTER IGNITION KEY IS TURNED OFF / TURN SIGNAL AND WARNING CHIME DO NOT SOUND. THIS REPLACES ITB03-055 DATED 8/20/03. ( NHTSA ITEM NUMBER - 10003514 )
infinititech1
i'm good like that when i wanna be
